Prepping for a 60k trail race and advice for an activity setup
Just upgraded from a Forerunner 210 to a Fenix 5x. Talk about worlds apart. I bought the watch specifically because I'm doing The Grand Traverse (60k trail race) this September. From what I can figure out the maximum time for the race is 12 or 13 hours. I should be well under that, but you never know.
I really like being able to track all different activities on one device. I have noticed that there about 1001 different ways to configure any given activity. I've done some Googling and really haven't found anything that talk about tracking options on battery life. I get that turning off the 'activity metric' will help from an every day stand point. I'm really focus on getting the most battery for my buck when in an activity.
I'm using my current Trial Run activity as a base line.
  • Data Screens - The stock ones plus two custom
  • Alerts - Distance 2.5mi / Time 45min
  • Metronome - off
  • Maps - didn't change / use sys setting - yes
  • Routing - didn't change
  • Auto Lab - 1mi
  • Auto Pause - off
  • Auto Climb - off
  • 3D Speed/Distance - off
  • Lap Key - off
  • Auto Scroll - off
  • Segment Alerts - on - no clue what this does
  • GPS - Normal
  • Power Save Timeout - Normal
  • Background/Accent Color - didn't change
My in activity backlight settings are:
  • Keys - On
  • Alerts - On
  • Gesture - Off
  • Timeout - 8 seconds
  • Brightness - 50%
Here goes with the questions .....
Will copying an activity still allow Garmin Connect to track it correctly. For example: if I copy 'Trail Run' to 'Trail Race' will it show up correctly in the Garmin ecosystem?
I don't really train to my heart rate, but its nice to know what it is. I do you the daily heart rate and heart rate during my activities. I was thinking of turning off for the race. How much does turning off the HR really buy you?
I've been putzing with the Courses function and its pretty nice. I can see the elevations profile and progress. This is really nice on hill repeats where I would normally loose count. The ETA is normally pretty close. The turn notification is nice when I'm not 100% with a new route. Overall its pretty darn cool. If I'm already using the GPS tracking, how much of a battery penalty does adding course navigation have?
I'm planning to leave my GPS setting set to Normal for the race because I got a GPS for ... well ... the GPS. I don't think GLONAS would really help that much on a trail race going over high alpine terrain. The manual doesn't explain what UltraTrac is, but I assume its a lower sampling rate and there for less accurate. Does this sound reasonable?
What other settings can I look at that may impact battery life?
  • Backlight is one of the biggest user controllable factors in battery life. Each 10% of backlight uses approx. 1.5% battery per hour. I would recommend turning the backlight down to 20% (or even 10%), and perhaps have the trigger settings During Activity set to After Sunset rather than On.
    If it was an event over alpine terrain, no way would I turn the course navigation off. In those conditions, I definitely want to know I am following the correct route. While there are some extra calculations involved, the big power drain is having the GPS chip active, following the course and turns is minor. However, if you are just following the GPS breadcrumb trail, then you may want to turn off mapping (not having to render maps saves considerable processor effort and battery).
    Ultratrac does sample less frequently, but the exact duration varies - it will sample less frequently if the compass and gyrosopes suggest you are heading in a straight direction, and more frequently to confirm a turn if they suggest a change in direction. I agree with keeping it on normal.
  • Will copying an activity still allow Garmin Connect to track it correctly. For example: if I copy 'Trail Run' to 'Trail Race' will it show up correctly in the Garmin ecosystem?
    Yes. A copy of "trail run" will show as "trail run" in Garmin Connect.
    The optical HRM in the F5 is very power-efficient. I would not expect any significant savings on a 12h race.
    Never done it on the F5, but on other Garmin watches course navigation does not impose any significant battery power penalty. And course navigation being a very useful thing in a long trail race, I'd definitely leave it on.
    Very good.
    Indeed, cases where GLONASS makes any difference are quite rare, and contrary to some of the above discussed aspects, GLONASS has a significant impact on battery life. I always keep it off for my ultra trail races.
    Your understanding is more or less correct. I'd strongly advise against using ultratrac for a 12h race.
    I'd reconsider your backlight settings. Depending on how often you use the buttons, it might reduce battery life. For battery saving I keep my backlight always off, and turn it on manually with the "power on/off" button whenever backlight is necessary. And major portion of the race probably will be in daylight anyway.
    Another thing to consider would be giving up on custom IQ datafields, as the IQ virtual machine is power-hungry.
    My experience is that there is a huge batterysave when in alpine terrain if you set compass to off when using map screen due to unstable speed from GPS going up the mountain. It prevents the map from flickering around every armswing..
    I turn the compass on, only when I need to look around me
    best regards
    Stig Erik
  • I use the trail activity default.
    When on trail race, switch off backlight, no need it on daylight, by night I use a headlamp so, needless for me that backlight.
    No sounds, alarms, etc
    No Glonass
    No maps or navigation, on trail race you just follow sings, arrows, other runners, etc
    No activity monitor.
    Always use heart rate.
    Never use ultra trac, I prefer 1 sec by default.
    Up to 14 hours on a race with this setup and 25% battery remaining.
    I always carry cable and a usb battery, just in case. You never know if you have to navigate, you will need more battery.
  • No maps or navigation, on trail race you just follow sings, arrows, other runners, etc
    On very long ultra races you sometimes run just by yourself, without anyone else within the reach of eyesight, and there is no one to follow. Some races have very sparsely marked routes, so it is not difficult to get lost especially when you're exhausted, both physically and mentally. I agree that a detailed topo map is an overkill, I do however use course navigation whenever possible.
    Very interesting. I had no idea the IQ fields ran in a mini VM within the OS. I just assumed they were running the same as the OEM fields. I'll start with only using 1 IQ field. I'll also take a hard look at the data I use and see about using the OEM data fields. Does adding additional pages with OEM data fields impact battery life?
    best regards
    Stig Erik
    I follow what you are saying, but I'm not finding any 'compass' option on my watch. Under the Map settings I did find that option to use Track Up or North. Is this the option you are referring to?
  • I recommend that you get some long runs in as preparation!:D
  • I'll start with only using 1 IQ field.
    The best way would be to give a try before the race. It might be that the power cost will not be that significant, and if you have some favourite IQ datafields that you find useful, then the tradeoff might be worth considering.
    I almost never use IQ datafields, but I have some activity profiles with a lot of built-in datafields, and I never noticed any impact on battery.
    I hear that and altitude training. There is still snow on a lot of the high trails. Runs over 10k feet may have to wait until next month.
