Hello,
This morning I was charging watch, and I check folders in watch memory. I saw the language files and I open a random one with notepad.
Can we edit that files ? If it is possible , I will translate menus to my native language.
You cannot edit files directly, presumably to protect the integrity of the file system.
After editing the language file on an external device, drop the new file in the GARMIN/NEWFILES folder. That's the normal way to update files but I have not tried this myself with language files. After disconnecting from your PC it should install your new file.
Two tips:
- Keep a copy of the original file you edited
- Remember the sequence of key strokes to change the language so you can change it back if it al goes wrong
Thank you.
I did exactly the same as you described, but no effect.
Maybe this is an issue proper to APAC version of Fenix 5, seems that languages files modifications are not applied (maybe they are hardcoded in the firmware like for English language ?)
Any help would be welcome
