Initial impressions, I love it. Was very stressed about the size. I thought, for me, the Fenix 3 was enormous which helped to seal the deal on returning it. Absolutely love the size of the 235. I'll attempt to add a picture (F5 vs 235) but this thing is BARELY bigger (was considering the 5s but glad I did the 5 already). When face to face you can barely see the 5 sticking out around the 235. Including the bump (on the 235) the thickness doesn't seem too different but on the wrist inevitably the F5 will have to stick out more. NOTICEABLY heavier but in 30 minutes i'm already getting used to it (note the 235 is LIGHT) so the change is noticeable. Out of the box before even activating GPS the altimeter said 719' (sitting upstairs of my house but ground level around here is 700ish). Will be running a known route 8 miler tomorrow (off day today) and 18 Sunday and will probably follow the same route as I did 17 last weekend and then just add at the end to compare tracks and mile splits. If those go good i'm going to be very happy with the decision to pull the trigger on the F5. If not.....well i'll try to not think about that. I was happy enough with everything i've ever had on accuracy except the F3 so hopefully they got that right this time.
Edit: Sorry the picture flipped sideways, it's saved correct on my computer? Also on size note the F5 looks a little bigger maybe due to the "tabs" that the bands attach to that stick out different from how they attach to the 235. Also the bands themselves are almost identical in width to the 235 ones.
