Topo Full vs Topoactive maps
Whilst my unit is a D2 Delta, I think Garmin checks out the Fenix forums more regularly....
When I first bought my unit about 3 years ago, I was thrilled that the Topoactive maps were provided and it was a novelty to do my walks with the map and navigation. However I soon found that many major landmarks (like train stations) were not in the navigation database. When I chose the nearest landmark, I ended up being navigated through some wild terrain. Now as I knew where I was going I simply ignored what the watch was telling me (especially when it decides to lead me in the opposite direction of where I want to go).
So, I decided to purchase the Topo Full V6 (Aus/NZ) maps to see what it offers. Sure enough, this has been rock solid with all the landmarks I want in the database and navigation is what I would expect. Great. However, Topo Full never gets updated whereas Topoactive does.
Now my question ;
I always have both maps installed and activites use Topo V6 as default. Works very well. However, of late I am noticing that street changes are not reflected on V6 (as expected as it never gets updated). If I swap to Topoactive then no problem. Except navigation sends me in weird ways and those landmarks I woild like are not there.
Would anyone know how the unit handles multiple maps? If the default map is Topo V6, will it still use the updated database of the also installed TopoActive? Basically what I am asking is will the unit create it's own pointers based on both Topo V6 and TopoActive but using the most recent data for any updates? I know that the V6 map does not reflect any updates that the Topoactive map contains (for example, there is a street that was blocked 2 years ago and TopoActive reflects this, but V6 does not - of course as it never gets updated).
If any Garmin people are looking at this, will ther be any updates to Topo Full maps?
A.
  • Topo full maps get updated but certainly rarely when compared to the TopoActive maps which are updated to reflect changes frequently. As for a timeline on the full topo map being updated, it depends on the map vendor that produces it. Unfortunately, it is impossible to say when those updates will take place.
  • Thanks Chris, I take it these are paid updates vs free for TopoActive?
    in reference to navigation, if the up to date TopoActive has say a trail that the TopoFull map does not and I start navigation to a point that can utilise this trail, will Navigation use the trail even though it is not displayed on the map? To clarify, my watch has both maps loaded and thus I get a comprehensive list of waypoints so in that respect it does seem to combine data from both maps.....
  • If you buy a full topo map, you are correct. You must buy a new full topo when released to update it. You are also correct that your TopoActive map that comes on your watch is free to update.
    If one map installed has more detail vs. others, it is best to go into your Map settings and disable the map you are not using at the time to encourage your watch to route that map.
