Recieved the update this morning and installed it.
Let's see how this one is going to run.
I have problem with map loading time (latest map version). Everything takes noticeably longer and and often reboots.
Have you same problem?
I've had connectivity problems since the update: every time I'm away from my Android phone and the watch disconnects from the phone, they don't reconnect without me removing and re-adding the…
Garmin, please check the battery management. Since the new 8.40 version, the battery live has been significantly reduced, especially if I track an activity. E.g. during hiking, the battery went down from…
Heads up.
My sensors, all of them, would not automatically connect after the update. I removed each individual sensor. I turned the watch completely off, then back on. I activated each sensor, in turn, and had the watch do a search for the current sensor. All is fine...now.
This morning did a first run with 8.40. I had no issues connecting my RD Pod which I did not use for months. Normally I run with HRM Run. Also no issues with navigation was spot on al the time. After 1h40 run (RD Pod , GPS+Glonass, phone was connected) battery dropped around 14%, at the moment do not notice any extra battery usage after the activity.
