Hello,
Hello,
same mishap... route-cannot-be-deleted---think-it-is-broken
perhaps you could help each other
happy & safe sporting
Couldn't find solution. So I resetted the watch. In the last 1,5 years this happend 3 times to me. Really annoying
I don't want full reset watch :( Status training and others will be reset too.
use Physio TrueUp or TrueUp and backup/restore
loosing stats is not the end of the world, believe me
otherwise call Garmin Support
or
report here the content of your COURSES folder
or
delete and re-create the COURSES folder
or
delete COURSES folder
restart watch
check folder
when not present re-create
and do to hard reset by press and hold the light button until the screen goes dark
afterwards sync time when not already done automagically
I know this from my experience: problem is connected with creation new route (garmin connect web) from an existing one (friend activity) and pre-set with friend pace. Without pre-set friend pace nothing problem.
you wanted a solution for your sticky course
does this sound familiar to you, the why explanation in the above post ?
I'm not sure. This time I used the Komoot App to install on watch. But the times before it happen by importing an GPX file.
For me it seems that Problem mit appears, by importing route to Garmin Connect and syncing this to smartphone.
related forum thread route-cannot-be-deleted---think-it-is-broken
tip from user Former Member
Have a look at this thread: forums.garmin.com/.../corrupted-courses
Solved this exact problem for me.
Probably a long shot, check in new files folder on watch. If remember correctly, I had files that stayed there if they were faulty. But was showing up in course list anyway. I think it was international characters in course points or course name or something like that.
