Pool swim function works great, open water swim function doesn't work at all. Does anyone know what could be my issue?
Sometimes it gets stuck cause it loses the GPS signal but then comes back, is yours completely stuck? Have you tried first connecting to a satellite (Green GPS signal) and then starting your swim?
Thx for the reply. I've performed a bunch of different tests.
One instance, starting it from the shore with the green GPS on. Then swimming out past the breakers to the first marker and taking a right. The watch only recorded the distance to the marker and stopped. I swam for about 45 minutes after that, unrecorded.
Then I decided to try the pool mode in the ocean and it worked well so I would start at the shore and swim 400-500m out and then stop pool mode and start another separate open water tracker and when I got back to shore it read that I went 0 distant.
I've tried to the use open water function about six times now and it either gets stuck or doesn't recorded any information.
What is peculiar is the pool function works perfectly? The problem is, I bought the watch to track my ocean swims
As for every summer, we have to wait next summer...maybe!
I got it to work when I tread water and stick my wrist out of the water at the points where I change direction. The GPS catches up and calculates the distance at those moments and everything works well. The only bummer is treading water one-handed for a little while, a couple of times during my swim but (in the end) it does work. Thanks for the help!
A mi me pasaba lo mismo, la solución fue:
1_acceder al reloj desde Android File Transfer
2_borrar todos los archivos que me permite el reloj (mapas incluidos)
3_ restaurar el reloj
4_conectarlo a Garmin Espress y volver a instalar los mapas y el resto de archivos
Desde entonces mis actividades en aguas abiertas funcionan perfectamente, incluso ha mejorado notablemente la precisión en trail running entre los árboles.
Un saludo
Just to make sure: If you breaststroke it won't work since the watch is submerged all the time. Front crawl is usually as good as it gets. I get reasonable accurate tracks during open water front crawl swims.
