Fenix 5+ version 6.0 notice
Checked on Garmin Express, and noticed that an update to Firmware Version 6.0 is available, along with BTLE, Sensor Hub, and something else was available. Anyone got the changelog so I can see what I've done to myself?
  • Can you get GE created Routes to appear on the watch?
    Yup, working fine. As a further test I just created a new route in Explore on my iPad, added to the collection that syncs with my 5+, synced with the Explore servers, then opened Explore on my iPhone and synced Explore with my 5+. I then opened the Navigate app and went to Courses and the new Route from Explore was there (with a stupidly long time, but that’s a known issue I believe). You mention going to Navigate and then Activity (rather than Courses), that may just be a writing mistake but if not that would explain things (Navigate Activity looks up your past recorded activities rather than Courses).
  • I select the Navigate App ( meant app before, not activity)...then Courses...the only option in there is 'Create New'....is this the menu path you are following or am I missing something (a new user!)
  • A [nother] forget and re-pair did the job...seems to be working fine now...apart from the time issue you mentioned, I also have that...
  • I updated. Only issue so far is the sync control would not connect and slow my watch down massively until it had failed.
    Sync via the WiFi menu and it was fine. Had to remove the sync control and re add it and then it worked.
    Makes me.really question the quality of the programming model of the OS.
