https://connect.garmin.com/modern/activity/3163019628
Is there a setting I should change?
Thank you!
The issue is with the last one right? Sometimes these things happen. Do the run again and see if it repeats itself. Overall it doesn't look too bad. Did you calibrate the altimeter before you started?
