HRM Run metrics not recording after 2 minutes on Fenix 5 Plus
I recently just upgraded my fenix 3 to the Fenix 5 plus. I have noticed that during running activities the following metrics are not recording past 2 minutes: Stride Length, Vertical Ratio, Vertical Oscillation, Ground Contact time, Ground contact time balance. The only metric that is recording correctly besides HR is Cadence, which might be coming from watch directly and not HRM run??
I am pretty sure it is not an issue with the HRM Run because all worked fine with the fenix 3. Any run I have had with the Fenix 5 doesn't display which has only been two runs. ciq.forums.garmin.com/.../1386477.png
