Triggering WLAN synchronization reports error on first attempt
When i trigger a WLAN connect/sync from my Fenix 5 plus, i always get a fail message at the first attempt.
When i trigger it again, it tells me that synchronization is already running!?
Removing/adding my WLAN did not make a change, neither a reboot.
As sayed it's working just the message displayed is wrong.
I hope that bug gets fixed in the next release.
    I got further strange behaviour of the WLAN sync.
    It tells me it's syncing but it doesn't... no matter how often i start the WLAN sync manually.
    I can see on my WLAN-AP that the watch is only connecting for a second or so and then disconnects again.
    It's definately no problem on the signal-quality or network or AP side!
    The only thing that got it work was to activate and deactivate the DND mode once - after that it synced over WLAN.
    I'm starting to get really frustrated with this 800,-€ really expencive watch.
    Bluetooth and WLAN are not working reliable, stairs counts are wrong, and pulse measurement is kind of random number generator (using it for biking). :confused:
    Considering to return that piece since i really HATE UNRELIABLE AND BUGGY software!!!
  • Did you try newest beta that come out yesterday?
    Thanks for the hint - will install it immediately and test it.
    I'd loved to read "solved" instead of "improved" connectivity issues...
    Unfortunately, the exact same bug still exists in 5.31 :(
    I meant 3.53
  • it works for me now. I had the same issue before but now it works all i did was restart my watch.
