You can't be serious! Fenix 5 freezing when syncing/charging on Mac
I know there have been several threads posted on this topic. I have read at least 10 different discussions but all of them are from 2017 and I can't find any recent discussions on this topic.
I know there is a workaround (close GC, then eject - which doesn't work for me, I might add) but surely they have fixed this, no?!?!?
Currently, my watch is behind 24 minutes, won't connect to Wi-Fi or BT... Don't know if I need to manually set the time or if there are other options.
I have performed multiple soft resets.
Do I need to blow it up, perform a hard reset and use my Windows work laptop as my primary? (Surely this can't be the case, right? I mean, SURELY the Garmin is compatible with a Mac without hacky workarounds, right?!)
This is a joke! What an embarrassment...
I have had a Suunto device and no fewer than seven (7) different Garmins with mixed results. My Fenix 2 - which is the device I used before upgrading to the 5 - was BOMB PROOF! It. Just. Worked. Perfectly.
I have a bad feeling I made a big mistake...
