I have just received a new approach z80 and have had it on charge for over 4 hours the led is solid blue but the unit will not turn on any suggestions. Thanks William.
Try long holding your down arrow/power button until it powers on. It is considered button #2 in the manual - Approach Z80 - Turning on the Device.
If you cannot get it to respond, please update the software using Garmin Express on your computer. Then try powering it on again.
Hi Chris i have just had my Z82 delivered and it has a solid blue line even after charging for the required time. when i go to garmin express to update software the device is not recognised any suggestions
When you have the Z82 plugged into the computer and you look through the scope, do you see anything or is it blank? Have we tried different USB ports on the computer?
You can also try restarting the computer, otherwise you might need to try a different USB cable. You can use any data USB cable you may have in your house for other electronics.
Rob
thanks it started to work after a few minutes
If you have tried all the suggested troubleshooting, please reach out to the Golf Product Support team so they can assist with exchanging the device.
