Played on Thursday, watch recorded ok. On Sunday it would only allow driver, 5 wood, hybrid as selections to record club used - no irons.
I am sending you a private message to gather additional details.
Last time logged into Garmin Express (Sunday) an update was available for 'Golf Clubs'. Installed and has rectified issue as played today and all clubs were available for selection. I think that updates somehow create a conflict in the programming and need resetting on occasions. Connected today and this update was displayed again. Can only assume that you cannot pre select updates from a data base from Garmin, would be handy if you could. Hope this helps.
Hi everyone who has had the same issue. Since I started this thread ( I think) I haven't experienced the problem since updating clubs from automated updates. I haven't changed any data relating to clubs on Garmin Connect 'Gear' tab, so don't know what happened. Rob did not provide any explanation from Garmin! Can only suggest as before that there is some sort of software conflict happening. What I did when this happened on a round, was to manually note what club was used and then amended the info on the scorecards page. This should then update your data on average distances etc. A reply would help Garmin!! Hope you all get back on track soon.
Can you also tell me what the solution is. Same issue, only 3 clubs showing under shot tracking. Please advise of fix. Thanks.
Hi 1849314, If you look at my posts, 5 & 4 months ago to Terat and DDAVI, they should provide the answer. When updating watch there was a 'Golf Clubs' update ready for installation, in addition to the normal course and software updates. I installed this and the watch reset itself. Haven't had an issue since. I do not use the Garmin Connect app on the phone, choosing to connect the watch via the USB charging cable to the laptop to download info. I can only suggest you also try this. I am very surprised that Garmin have not addressed this issue in this time frame. Good luck
