I can not perform Search Out of my State and locate "a known address" .
Even after looking on the map to ensure it exist. I can't get known cities (by name, out of state) to appear after inputting the correct information by Name, Providence, Zip Code, or States. I have also used the highways federal, State, etc names in lue of the street names. The only way I have found to navigate, is to place a WayPoint at the address. The search function works OK within my state boundaries however.
Am I doing something incorrect?
I use the State name and confirm is correctness.   I have done the same with the city name by itself.
Confirmed the newest Zip Codes. ETC....
  • Which device do you have and what maps are on it? TopoActive for example doesn’t support searching on address.
  • Also, please provide the exact steps you are taking to search for an address.
  • Garmin 710i
    STEPS:
    1. TURN unit on.
    2. Ensure the correct Maps are turned on thru Map Manger.
    3. Magnifying (Search) and open the "Addresses App'
    I reside in "South Carolina" (SC) and say I want to go to "Richmond, Virginia"
    4. I change Search Area to "VIRGINIA" y tapping on the SC and it switches to change the Search Area.
    I then have these options: Enter City/Postal Code OR Enter State/Province
    So lets say I'll use the State Name "Virginia" for the area search
       Then I select the name Virginia the unit locates during its search.
    The next parameter to search is, "Number"
       I enter the address number of "8716" where I used to live, tap Enter
    The next parameter to search for is "Street Name"
    In my case that is "W. Broad St." Tap enter
    Response is:
    " No Results Found"
    "Try adjusting search parameters."
    Software v 23.10
    Latest updates installed but the Address App still does this.
    Sorry new to this here and Thanks for listening
  • Montana 710i
    Automatic maps is enabled
    City Navigator
    CN North America. 2025.20 ALL US
    GARMIN DEM NORTH AMERICA 2023. 10
    ToPo ACTIVE US 2024. 20
  • I forgot to mention also that I have tried other states, other cities, and known and addresses that I have gotten off of my 710i and then tried to search for.
