Is it normal for the torch to flash once when you first turn the Montana 700 on?
Thanks
Thanks
Hello, are you able to provide a short video of this happening?
Hi, the Garim 700 has a torch feature, when you turn the unit on or plug into USB the torch itself flashes quite brightly and you can hear an electrical noise. I will try and video when I get home. Thanks
I’ve taken a short video. I understand from a Garmin sub dealer that this is a known issue / fault with firmware 19.0?
