Montana 700i display frozen after display update
Today I’ve updated my Montana 700i via Garmin Express to firmware 6.30 and Display update (available in Express). After restarting, the display was stuck on “New software found. Continue installation?” : but when trying to go further, I cannot press either Yes or No. The display is not reacting, Tried to reset, reinstall firmware through WebUpdater (which is saying I’m on latest firmware 6.30 but when trying to reinstall is going with 5.30...)...nothing. Dead
Seeking help on Garmin site, I’ve ended up in chat with the tech support and the solution was to format the GARMIN in mass storage mode to FAT and then update the firmware in Garmin Express. Although   curious at least (the solution) I did it and the result was as anticipated: nothing else on my Montana memory...empty. Now Express is not recognizing it, WebUpdater is getting constant failure at firmware reinstall and my Mac is only recognizing it after the usb cable remove, power off, power button pressed the after red led coming to life, usb cable in and... fingers crossed...
  • Hi
    Does this issue only occur when the 700i is updated via a mac computer or does it occur with PC's as well?
    I am hesitating to update my  700
    thanks
  • I don’t think is computer related but more to a firmware bug.
  • I may have gotten lucky since my Touchscreen update loaded 100% and works normally. But successful Mac interfaces with 700i’s are 0 for 3 on this thread. (I’m still showing version 5.30 after the Touchscreen update) Dr Kayak didn’t say but I’m guessing a Windows computer yielded version 6.30 without issue.
    Also, one of 6.30’s listed Fixes was mounting SD Cards formatted on Mac Computers
  • I don’t think is computer related but to a firmware bug.
  • Hi Andrew,
    I cannot find 6.30 release notes anywhere. What does the 6.30 update fix or introduce? Is it safe to install it via Windows given that some of the users here report issues when updating the fix?
    Cheers
  • Same with 750i. Software update available. Do you want to install? Yes was the last the screen responded. Hard reset. Still no screen. Update via Express (mac).  No screen response. Replacement en route from retailer.
  • Saw this on advrider.com thread:
    Change made from version 5.30 to 6.30:
    • Added wifi icon flash on status page/status bar when wifi on but not connected.
    • Added custom patterned lines for other road types.
    • Added the ability to lock/unlock the configurable fields on the corner data fields dashboard.
    • Added a lock icon on confirmation pages to clarify auto-lock status.
    • Added configurable fields on the corners of the map page.
    • Added a "note" option for logging geocaches.
    • Added the ability for the measure distance function to start at any point.
    • Added Rain mode to Touch Sensitivity settings.
    • Improved map drawing times.
    • Improved filename time formats.
    • Improved inReach activation prompts.
    • Improved swiping on the status page.
    • Fixed issue with lock icon not showing up on secure wifi networks in night mode.
    • Fixed issue with shutdown when sorting photos by date in photo viewer.
    • Fixed issue with geocache proximity alarm causing slow start up times with .ggz files loaded.
    • Fixed issue with slow start up after deleting .ggz files.
    • Fixed issue with font on corner data fields dashboard in night mode.
    • Fixed issue with the widget page indicators occasionally blinking on the status page.
    • Fixed issue with text alignment for inReach messages.
    • Fixed issue with flashing on the photo viewer.
    • Fixed issue with potential shutdowns when navigating tracks.
    • Fixed overlapping icons on the map page with corner data fields dashboard.
    • Fixed issue with the wifi status not updating.
    • Fixed issue with "track up" and "north up" map orientations.
    • Fixed issue with manual route transitions.
    • Fixed issue with the tabs/status bar flashing on the geocache page.
    • Fixed issue with zoom levels on round trip routing pages.
    • Fixed issue with getting a false max number of photos exceeded message.
    • Fixed issue with Explore sync and map settings.
    • Fixed issue with CIQ apps and widgets in landscape orientation.
    • Fixed issue with auto-zoom on the weather map.
    • Fixed issue with copy-as-reversed fit activity stats.
    • Fixed issue with truncation of a data field on the trip computer page.
    • Fixed issue with mounting SD cards formatted on Mac computers.
    • Fixed possible shutdowns when using Birdseye imagery.
    • Fixed Express sync errors due to empty current activity file.
    • Fixed "off road" label for routes that were not off road.
    • Fixed issues with geocaches not showing up when attempting to program a chirp.
    • Fixed issues with truncated translations.
    • Fixed issue with overlapping text in the geocache info box.
    • Fixed issue with the "Go" button not appearing on some routes.
    • Fixed issue with geocache filters turning back on automatically.
    • Fixed a potential for a shutdown on the map page.
    • Fixed issue with adding via points.
    There may be additional unpublished changes included in this update.
  • I successfully updated my 700i to 6.30 with my MacBook Pro.
  • I tried syncing my 700i to Express a couple hours ago (2015 iMac) and it's still telling me I’m up to date with version 5.30
