Confirming High Detail Activity Recording is still broken in this update, will not record High Detail if Auto Track is On.
Will only record a quick burst of points at extremely coarse 10-minute intervals.
Just a question: without using autotrack, high detail activity recording is working for you?
No...and maybe yes.
No because it's not mine, I got it for my partner as a safety device. She doesn't remember to enable High Detail manually every time, and even if she did gets confused with the tracking/recording terminology and config settings. Even experienced users get confused with this. And this would be particularly an issue in an emergency, so in a product functionality sense setting manually doesn't work. We just need it to honor the feature set and simply come on when it's turned on
Maybe yes in a technical sense. If you enable High Detail manually you will normally get high detail. However, this issue is only one aspect of a series of associated instability issues we have noticed. High Detail & Auto On is the most important one, and the one I'm narrowing down on in the hope Garmin may actually fix. But there are also others in the list I reported a couple years ago that are less common but can also impact:
