Mini 2 displays wrong bearing to a saved waypoint .
Can anyone confirm this, from the mini2s startup screen, press the ok button, select saved, select waypoints, select a waypoint, press ok, select, view details, the display shows the coordinates, the distance, and the bearing to the selected waypoint. Except when you rotate the mini it is obvious the bearing is actually your heading, as it changes, it’s not the bearing to the selected waypoint. Software version 4.22
