Internal test inop?
Messenger running and can operate , send track points and msg etc.
When I try to use the buid in test by going to menu, IR, Test,
I can start the test, GPS fix is obtained (even when this is already tracking) and then test msg seems to be sent, or at least the messenger says so.
Then comes waiting for response, together with advise to place the device under free sky....
( or connect it to messenger app ?!?)
there is however no result received, after abt 30min, the display changes to something like 'you probably have no plan'
This is not true, all works otherwise, plan is in fact unlimited and the device is under free sky all the time.
Did someone managed to use this test successfully?
