67i clock one hour off
My GPSMap 67i displays daytime exactly one hour off, it is always 1 hour earlier than official time.
Issue has started roughly 2 months ago, I own the device for more than a year, never had any other problem with it.
Software version is 9.10
Time settings are 24h and auto day light saving and correct time zone is selected (Europe West in my case)
Changing to manual day light saving does not make any difference (changing now to winter time makes it to show 2 hour difference obviously)
Situation persists even after longer periods of active tracking. Location etc is displayed as normal
Synced many times with both Garminn Express on my PC and Explore on my Android phone, without further issues
Also software on PC and phone are up to date
Any idea how to fix this?
  • Mine works fine, 24 hour and automatic or set to Canada Pacific Region, either one but you can’t have both of course. What if you just select automatic instead of  Europe West ? Version 9.10  Has there been any new time zone changes in your area other than the daylight savings time change? Did it go screwy when the daylight savings time change occurred ?
  • Where are you located and are you sure West Europe is the correct timezone for that location?
    Also try setting the timezone configuration setting to Automatic, the device will then use the correct timezone based on the GPS position. See Main Menu > Setup > Time > Time Zone.
