Haha it shocking you just close the topic instead of replying? Its highly disrespectful for someone who just purchased these 2 items and need an answer sooner than 3 days it takes to get a reply via your email.......
If you KNOW the answer, why not help and then close it? Obviously you work for Garmin as product support and can easily help instead of just neglecting. Wow what a horrible first experience with Garmins support.
Its simple questions for you?
- Does the 86i device support g3 Vision or only g3? --- Yes or no?
If I understood the following correct, https://support.garmin.com/en-US/?faq=xRlMwaRfg8182UzTFp3nY5&identifier=662559&tab=topics , it is supported. But I also read a comment from a gps reviewer saying g3 vision is NOT possible with the handheld GPSMAP 86i, only g3.
Which one is it? - If I purchase a g3 or g3 vision map for my GPSMap 86i device, and would like to view the same map and control it on my touchphone ... Is there an app for that that sync them together in that way?
IF yes, which one?
IF no, ok then... moving on...
