When the system boots, I receive a notice "Cannot Unlock Maps". I have to "enter" in order to dismiss the alert. I have reset the device to factory defaults, however no change in symptoms.
Any assistance would be apprecaited.
Worldwide DEM Basemap, NR
TopoActive Americas, North 2021.20
TopoActive Americas, Central 2021.20
Device model and firmware version?
GPSMAP 66i
8.50 (548803)
Are those maps listed in the Map Setup page? Are you able to view them on the Map page?
While the map is displayed, I select “Menu” -> Enter -> “Configure Maps” -> enter. The three maps are “enabled”.
As a test, I disable all three maps. Nothing is displayed.
Only Enable Worldwide DEM Basemap -> roads are displayed.
Only Enable Topoactive Americas, North -> Nothing is displayed
Only Enable Topoactive America, Central -> roads and topographic information is displayed
OK, sounds like an issue with the TopoActive North America map installation.
Please use Garmin Express to re-install the TopoActive North America map!
T2PILOT Hello, please use the following link to troubleshoot the issue "Can't Unlock Maps" Message on a Garmin Outdoor Handheld.
