wifi not connecting
Tried today to connect to a wifi other then in my home.
First tried on the 66i, setup , wifi, then add network.
The screen went blanc , abt every 10-15 sec small 'search circle' flashed up for a second at the bottom of the screen, but then screen is off again.
OK, I got PC up, garmin express, did set up the network there, this went OK.
BUt surprise, when I disconnected the 66i from the PC and restarted it, the wifi network was there, but no way to connect.
The network is WPA2 protected, normal 2.4 band, SSID is broadcasted.
Where is the problem?
