Shot tracking
I love the shot tracking feature on the s70.
however, there is one big issue.
whenever you hit a shot onto or around the green, and you get close to the green, the display switches to the green view, and the distance counter for your ongoing shot disappears and is exchanged by a distance counter to the pin.
is there any way of disabling the automatic green view or disable the pin distance tracker. I would like to be able to see at what distance my shots that land on and around the green end up as well as those in the fairway
  • When the zoomed in view of the green appears, the single distance value appears to offer one distance to the middle of the green or to where the flag was manually moved by the user. This is opposed to offering the front, middle and back distance views since the threshold of the green offering the front and back distances is no longer relevant since the user may be chipping on from the side or back of the green.
    The AutoShot feature on the watch is only designed to detect full swing shots, and the chip shots or putts are not designed to be tracked due to the lesser impact of the clubface hitting the ball. While the watch may detect a shorter swing, it is not designed to track from around or on the green. The CT-10 sensors allow for putts and chips to be tracked with the distances on the shot when reviewing after the round.
    Since the CT-10 sensors are required to allow for putts and chips to be tracked, the shot distance stops tracking when on the green to stop the shot tracking since the watch on it's own cannot detect putts or chips from there on.
  • That’s not really what I was asking.
    when you take a FULL SWING towards the green, that is detected, and you start getting close to the green, you no longer see the distance of that shot being tracked.
    I want to see the total distance of my DETECTED FULL SHOT once I reach the ball, even if it finishes close to or on the green.
  • Do I understand you correct: if you are on e.g. a Paar 5 hole with 450m and you are near the green, then you will see, that you now have done 410 m from the tee?
  • Just press the lower right button and you’re back on the same view like on fairways and you can see the distance of your last shot.
  • This is my biggest gripe with the S70. I want to know my shot distance, including those that land on or near the green. Switching to an arbitrary distance to the middle of the green or a manually manipulated pin placement is totally useless.
    I’ve purchased every Garmin golf watch they’ve sold and I swear by my S70 but, this “feature” (and the inability to disable it and prevent it from switching) is sufficiently frustrating that I am actively looking for an alternative solution. Not dialing in shots results in high scores and poor handicaps, not to mention, an increasingly negative in-round experience.
    NOTE: I know the functionality is possible as I experienced a temporary “glitch” where I was being shown both my active shot distance AND the distance to the middle of the green. Needless to say I was over-the-moon! Unfortunately, the experience was short lived (only a round or two) and I’ve suffered with the loss ever since.
    @Garmin, PLEASE give golfers the ability to choose which data we want/need. The only major flaw in the S70 experience is offering shot distance tracking, but taking it away on arguably the most critical “scoring” shots, when you really need to know your distances (under playing conditions) to dial it in, stick it close and, GO LOW!
