CT1 or CT10 sensors
Hi all,
I have an S70 approach and was about to buy the CT10 sensors for game tracking.
ive just seen the CT1 sensors have been released today and are listed as compatible with S70.
what is the difference between the two sets of sensors. CT1s are half the price of the CT10s, but otherwise I can’t see what the benefit of buying the CT10s over the CT1s would be at double the price
thanks
    • Was having the same problem, used heat shrinking wrap to ensure they stayed put. No issues now.
  • If using the CT-10 sensors, I would not recommend heat shrink wrap especially if the shrink wrap is plastic based...the rubber heat shrink tubes used for soldering would also not be ideal as the heat could potentially weaken the rubber on your grip or result in cracking of the grip...and then anything covering the entire CT-10 sensor may affect the sensor waking up and pairing to the watch when pulled out of the bag...as the sensor uses light exposure to wake up and pair after being pulled out of the dark bottom of a golf bag.
    One option that helps is using some plumbers tape around the threading of the sensor mount that screws into the breathe hole at the grip end. The plumbers tap can help thicken the threading if the breathe hole is larger on the specific brand of grips used on your clubs and holds pretty well against the rubber material of the grip.
    Using plumbers tape however, is not officially recommended by Garmin for the design of the screw mount...so you will want to test this out on your own if you choose to see if viable in keeping the sensor secured.
    Hope this helps,
    - Cody
  • What about a spot of hot glue as you screw it down to the club?  Hot glue is easily removeable.  I check mine when I pull the club out but haven't had any issues.
  • I cannot recommend using hot glue and or any adhesive-based type of application to attach the sensors outside of any leftover or folded in grip tape that is often folded into the hollow end of the shaft prior to the actually grip being stretched over the tape after the solvent is applied.
    The mention of plumbing tape in my previous comment is something that will thicken the threading on the screw mount without bonding like an adhesive will and does not involve the use of heat, or other factors that could potentially damage the rubber on the grip.
    The verified correct answer is to check the size of the breathe hole at the grip end to see if the threading of the CT-10 fits snuggly into the grip, keeping in mind that the threading is designed to fit most standard sized grips...but manufacturers, model of grip, and other factors will vary as to how snug the screw mount will fit.
    When re-gripping your clubs, you can also ask the shop professional installing them to fold the grip tape into the hollow end of the shaft opening prior sliding the grip over the tape so that the screw mount once through the grip breathe hole is caught by the unsprayed tape folded into the shaft to help hold on the screw mounts a bit more.
  • I’m using a S70. Works great, but for mij chips I need to add a shot manually, because there isn’t a real swing. If I would buy ct1’s, will it track the chips (and also putts) automatically, when tapped? Will I be able to use 3 sensors (wedge and putter) and track the others shots without tags?
  • Yes, the CT1 will "force" the watch to record those undected swings.
    For the putter, you can use the action button when on the green. CT1 is necessary if you want to record putt from the fringe or outside the green.
    All other club w/o CT1 can be recorded manually as far as the shot is detected and "prompt" is on.
    I've been using a full set of CT1 for about a dozen of round and I think using them for wedge is good enough.
    I'm actually a bit worry about scratch when I touch the screen with the tag.
