Hey Garmin moderators, maybe you can help me,
I play a course (https://www.miraclehillgolf.com/golf) once or so a week. Its data is screwy on garmin devices b/c they swapped the front 9 and back 9 holes.
I've submitted changes to https://www.garmin.com/en-US/forms/golfcourses/ probably 3-4 times over the last 2 years.
Can any of Garmin forum mods help?
Here is what I've submitted today (which I've submitted several times before):
When playing golf at miracle hills (Omaha Nebraska), I have these problems:
Problem 1: On the scorecard, the holes are in the wrong order. The 1st hole, is now the 10th. 2nd hole is 11th, etc... Example: Garmin's scorecard's hole 10, is hole 1 on the real course. Basically the course reversed the front 9 and back 9 probably 5-10 years ago.
Problem 2: The maps ARE in the correct order. For example: Lets talk about hole 12. The scorecard shows hole 12 as a par 5. This is wrong (see Problem1 as this is actually a par 4). The map, on the garmin map after a round, shows the correct map. The REAL hole 12 is a dogleg left par 4, just like the garmin map shows. The reason this is a problem is #3.
Problem 3: Since the scorecard and maps aren't lined aligned, the logged GPS shot data isn't correct. For example, in the real world, if I play hole 3, its a straight par 5. Garmin's scorecard shows that I played hole 12, and the shot data map displays the real world hole 12, so my GPS shots don't ever show up on the map. This would be easier to show in a screenshot or screencast... but this is because of problem #1 and #2.
