BugReport: S62 no Alert on Max HR (Zone 3)
Setup:
- Garmin S62 / Software 4.40 (BLE/ANT 2.00)
- Default Max HR: 185 bpm (I would like to unset, this to get the age based default back)
- Default Zone 3: 70 -  80 %
- Default Resting HR: 60 bpm (I would like to unset, this to get the age based default back)
-Running --> use default
- Heart Rate Wrist HR: Enabled
- Additional Sensor Polar H9 Connected via BLE / ANT (tested with both connection types same result)
Inside the Activity "Run" an Alert is configured limiting the activity to Zone 3 (High Alert -> Zone 3 - 148 bpm // Low Alert -> Zone 3 - 130 bpm). When running the Low Alert is triggered quite reliably. However the High Alert did not trigger, when running with 156 bpm (duration unkwown, but was most likely a slow build up to this heartrate) nor when running with 151 bpm (for most likely 1 or 2 minutes).
Further remarks / suggestions for desired features for running:
- Ability to unset / remove Max HR and Resting HR
- Ability to measure Pulse Ox Level (Currently only supported while sleeping)
- Ability to Measure Exhaustion / Recovery time similar to Forerunner Series
