What is the fix for my S62 not tracking my shots?
No detailed results for my round(s) everything else is working fine.
Top Replies
All Replies
    Hello! Try syncing that shot data manually with Garmin Express. This onetime workaround should push that data to the app.
    How to Sync Data from a Fitness Device to Garmin Connect | Garmin Support
  • This seems to be a recurring issue. I've had the same problem (albeit, with a Venu 2) and can make no rhyme-or-reason as to when it tracks shots and when it doesn't.  Looking at the .fit files on the device, they all seem to be roughly the same size so I assume the data *may* be there. I've been unable to find any tool that can display the golf-specific stuff in a .fit file, though.
    Unfortunately, sync'ing with Garmin Express doesn't seem to make any difference. I've also found that deleting both the activity and scorecard in Garmin Connect and the re-uploading the .fit file will only add the activity. The scorecard doesn't seem to upload except at the conclusion of the round (when it's successful, that is).  There are a handful of .fit files in Garmin/Score on the device, but they won't upload to Garmin Connect.
    It's frustrating as this is really the only issue I've had with the device all summer.
