My S62 will not charge when I plug in the USB cable.
This is a very poor customer journey and experience given the cost of this product.
Grateful if someone can advise and or assist me please in this matter ASAP
Hello, please try the following:
If the issue persists, we may need to get a new charging cable to you. Please reach out to your local Golf Product Support team using the contact section at the following link.
Did not work not happy at all
Mine doesn’t charge and has never given me the club selection. Very frustrating
I had problems charging it with an adapter. When I'm connecting it to a computer it will start charging immediately.
The real design problem is with the charging cord's (watch-side) 4-pin plug. The small pins are spring loaded and tend to get stuck in the pushed in position and don't deliver a charge. After every time I wear the watch I clean the back of the watch with a little soapy soft paper towel, use a wooden or plastic toothpick to clean around the charging port oval and then I check that the pins are all fully out at the same height. If any of those pins are down use a toothpick to pop them out. This sucks a little but the watch is so awesome otherwise I'll put up with this inconvenience. The two times I had problems turning it on was caused by a stuck pin so now I'm extra vigilant they stay clean and springy. I hope this helps other Garmin S62 owners with charging problems.
Same for me nothing to do no charge no icon i need to use my old fenix5
