Make it easier to delete/edit shot lengths for each club.
Hi, I would like to see an improvement on how to manually remove misscalculated shots for each club. As of right now you have to manually check through each hole and scorecard and manually delete the shots (or add more shots) to get the correct length if the watch have missed to register a shot after the one you hit with the club.
My suggestion is to improve the "Gear" page, both on Garmin Connect and in the golf app so that you can expand each club and get all shots registered with that club, and from there manually delete shots that you know is miscalculated. So for example currently I have a 300+ yard shot with my 3 Iron which is impossible, but to remove that shot I'll have to manually check through each scorecard and hole to find that particular shot which is a big pain in the ass with the amount of rounds I have played, so If i just could find it directly under the "Gear" tab and remove it from there it would be so much easier.
An improvement ontop of this would be to add a link for each shot in the "Gear" section that would redirect you to the correct scorecard and hole for that particular shot.
