Im using IPX with IOS13.5.1 and connected with S62. the rest of the notification seems working well but i didn't get any notification for my WhatsApp. any special setting required?
In iOS, smart notifications that display on your watch are based on your iPhone's Settings > Notifications menu default settings found on the top and the previews settings for each APP on your iPhone.
In Settings > Notifications > Whatsapp, ensure you have Options > Show Previews set to 'Always' (Default).
Check Notification Settings:
Open the "Settings" app on your Cat S62.
Scroll down and tap on "Apps & notifications" or a similar option.
Find and tap on "WhatsApp."
Ensure that notifications are enabled for OGWhatsApp. You should see an option like "Show notifications" or "Allow notifications." Make sure it is toggled on.
Check WhatsApp Settings:
Open Yo WhatsApp.
Tap on the three vertical dots in the top right corner to open the menu.
Go to "Settings" > "Notifications."
Make sure that notifications are enabled here. You can customize notification settings for chats, groups, and calls.
Check Do Not Disturb Mode:
Sometimes, if your phone is in "Do Not Disturb" mode, notifications may be suppressed. Check if this mode is enabled.
