Since 2 days I have the same with my score cards
You will not loose the data already uploaded to your account. I would make a note of all the settings in your S60 before a reset to remind you how to set up your watch. I would recommend to “forget the…
If you reset your watch to factory settings then set it up again it will work. Disconnect too from connect app then refund your watch. Loads on this forum had the same problem and this seems to fix it. Seems like a reset required after the recent major iOS upgrade on Apple.
Hope this helps.
