Plays Like distance stopped working
After I connected my S50 to Garmin Express and did a map update (Europe 7.20), the plays like distances do not display anymore.
Tappig/toggling them on does also result in layup distances showing as 0.
I have already set the watch back to factory settings (including deletion of data) and did set it up again. That did not help unfortunately. Firmware is Version 4.63
Suggestions on how to proceed and bring back the plays like distances are highly appreciated.
Note that I am off course...but I doubt that being on course would change anything as plays like used to always show before the problem started to occur.
  • Follow up:
    Support chat confirmed that there is a support case for this problem. Unfortunately, after two weeks, I have not received any feedback.
    Todays Map update to version 25.10 made it even a lot worse. Distances are way off.
    Kind of disappointed. Will return product and not consider buying another one.
    Disappointed
  • Hello,
    Garmin is the process of releasing a fix for this concern with the PlaysLike Distance no longer displaying after updating the course mapping.
    Once the fix has been released, users that have reported the issue will be notified via email from Garmin, and I will update the verified response here in forums advising from there.
    Our apologies on the timeline being longer than expected, as solutions related to software can take some time while the solution is being determined and developed...as updates to software is typically released to all users and a great degree of care is involved in this process. Communication related to a ticket in-progress is typically not sent until the solution correcting the issue is available.
    - Thank you
  • Hello Cody
    Thank you for reacting to my post.
    I want to share a positive development to the issue.
    Connecting with Garmin Express today hinted, that there is a map update available. While the acutal regional maps (Americas, Europe/MENA, Pacific) remained at the same version as before, the App did install 'CourseView DEM Worldwide 4.40' on my watch.
    This seems to have solved the problem with the PlayLike distances, as these do show again (and seem to be correct as far as I checked).
    There are still courses (or at least one), where the distances are way off as can be seen in the pictures I posted above.
    However, I reckon this might be a bad update by the data supplied from the actual course?
    I have checked the data for numerous courses, all seemed legit apart from one.
    I appreciated if you could comment on that - is there a way I can check with the actual Golfclub that specific course with wrong data belongs to?
    Is there a chance that actually being on the course and using GPS will have a correcting effect on the bogus distances shown offline?
    Thanks again, have a day
    Chris
    EDIT:
    I think we are good again.... I removed all previously added Golf Courses in the Garmin Golf Mobile App, downloaded them again and then synced the watch. That seems to have helped and corrected the wrong distances shown before.
    In other words... I am happy again ;)
    While there has not been any communication related to the mentioned ticket (yet), from my personal side it can be regarded as solved.
  • If you notice distances or other information displaying for a specific course it may be due to changes made by the course since our last update to the map for that club.
    For these reports, a golf course report submission through our site is needed which can be submitted through the form in the link here: https://www.garmin.com/forms/golfcourses/
    Note that if you submit a course report, it can take several months before an update is implemented into the bundled course map updates we release for everyone to install. Once a map update containing any fixes needed is available for the course you report...an email will be sent to you advising to update your course mapping.
  • Hi since my recent update my Plays Like Distance is not working.  I understand there is a problem, please notify me when the issue is corrected.  Thanking you in advance for your help. [personal information removed]
    Edited per Terms of Use to remove personal information from comment to the public thread. Admin here for the forum can identify your account through tools on our end, there is no need to include personal or account related information to the public thread.
    - Thank you
  • Hello there.
    I did have this problem after my first update (as described above in this thread). Even though Garmin Support did respond and was very kind, they were not really able to help me direclty.
    For me the problem seemed to have its cause in some Map Data missing. In the settings menu of your watch, you can check which maps are installed and I would assume that you do not see 'CourseView DEM Worldwide' there. This is the one needed I reckon.
    How did you do the update on your watch? Just over WiFi oder did you connect to the Garmin Express App on your PC?
    If it was over WiFi only, try connecting it to Garmin Express via USB and update from there. Make sure not to disconnect your watch before it is done.
    Hope this helps - keep us posted
    Cheers
  • Mine has never worked. Very disappointing really. ( but for it to work do you need to download the courses, not just play them over gps? )
  • Hi Karl
    To answer your question first: I do use the GPS when on course. But also when off course, and not using GPS, any course downloaded on the Garmin Connect Smartphone App does show plays like distances.
    As I hinted above, I strongly suspect that the feature depends on the Map 'CourseView DEM Worldwide' - but since this has never been confirmed by Garmin (nor have I ever received feedback on the support ticket that was opened), dont take this as a fact. All I can say is, that PlaysLike did not work while this map was missing and it is working again since it got added during an update via Garmin Express PC App.
    Can you check on your watch if you have this map? (Go to Settings - System - About - Map Versions)
  • Map versions is ... 25.10 with no updates available via WiFi or garmin express
  • Mine plays like distances worked great until my last update. I'm at current software 8.9. So frustrating for the start of new golf season.
