If Garmin updates their ToS and there is no WiFi, the R50 is a brick!
I spent hours and dollars to digitally and physically set up an important test at an outdoor range with multiple head and shaft combinations to choose which clubs to game. First screen on the R50 is to select a user, I select myself which is relevant because I had added the club/shaft combinations I would be testing to my account. This is the dead end that came up
I can not use my user without accepting the updated ToS which can only be done with WiFi and no WiFi is available! My iPhone's hotspot is never an option to connect to for some reason.
The best I could do was to use my R50 as a guest. This has one huge problem, as per the owners manual "Data recorded for guest profiles will only be stored locally." So I can not get the data off the machine so I can not analyse it as needed to choose which clubs to game from the test!
Again showing the R50 is not appropriate for out and about usage, only in a home simulator (Awesome golf is also impossible to use when out and about).
Garmin please make the R50 and all features functional when out and about, meaning with no WiFi. What would also work is if it could connect to an iphone's hotspot as the WiFi network.
  • I’d love to see the Garmin R50 become more user-friendly in offline environments, without requiring a WiFi connection. As you mentioned, it would be great to use the device with Awesome Golf, GSPro, or E6 in locations where WiFi isn’t available. One idea I had was for Garmin to develop a proprietary wireless transmitter that could plug into a laptop or R50, enabling third-party software connections without relying on WiFi. Alternatively, a hardwired connection option would also be a valuable solution.
    Here’s what GSPro customer support shared when I reached out to them about this:
    "We at GSPro unfortunately don’t have much control over how the R50 connects to a PC or our software. Garmin currently only supports the WiFi/Hotspot method, but I do know they’ve received feedback from other users requesting a hardwired connection option.
    I can’t say for certain whether that’s in development, but I’ll pass your feedback along directly to the Garmin engineering team we’ve worked with."
    Regarding your iPhone hotspot issue — I’ve personally been able to connect the R50 using my phone’s hotspot just a few days ago, so that might be worth trying again.
  • Yeah, this caught me off guard as well after updating and then going to the range to hit some balls. Ironically, I just restarted the unit using the power button and I was able to skip the screen entirely.
