Error: "Unknown battery" comes on and off. Can not connect to the device outside on the driving range in low temperatures (+5 C) and wind. Android 9 mobile. This is a new problem, after a year of working ok. Can the battery be "dead"?
This appears to be out of range issues.
R10 is connected to Your mobile via bluetooth, and distances above 10m are unstable.
Or a cold battery i guess.
If the message is unknown battery to me it seems like a misread of data other than lost connection due to device turning off.
But yes, the battery life will be hurt in cold temperatures.
I’m having the same issue, is there a fix? I’ve let it power down and recharge and same error appears. I’ve performed the reset a few times with no luck.
Nor necessarily a fix, but I would download mholow gspro connector, and install it on a windows PC.
Pair the R10 to the computer, and start the connector.
A lot of videos on YouTube describing this.
You should then get a lot of info related to Your R10 device, including battery status, tilt etc.
If the other data looks ok, but battery status is faulty, then it is something internal in the R10 unit.
If the unit charges (works on battery for hours), then the battery is probably ok and the charging function is working. Then it is probably the circuit reading the voltage (and thus battery status) that is faulty.
If everything looks ok, then it is the Garmin sw on Your mobile device.
