how do you keep proper distance from r10 and straight in line with r10, how close does it need to be for accuracy.
Doesn't moving the R10 mean the R10 has to also be re-calibarated ? If so, the software requires the session to be closed first in order to re-calibrate the R10. If it needs to be re-calibrated, the software should allow re-calibration without having to close the range or HTH session.
Moving the device does not require recalibration, unless the surface the R10 is being placed on uneven. Calibration must be done from the main menu of the Garmin Golf app, and with a level tool to ensure the surface is even for setup.
