My new R10 is staying in standby mode, it's connected to my phone fine and I have updated the software but still not working... advise please.
Hello, Does clearing the Bluetooth pairing history and re-pairing the R10 to the phone make any difference?
Are there a certain number of shots you can hit before it enters standby mode, and does this…
I just took out my new R10 for the first time today. I was outdoors and in driving range mode. I hit about 100 balls, the device was about 2.1m behind me, and I intermittently received the 'standby mode…
SAME AS ALL THE OTHER PEOPLE WHATS THE SOLUTION ?
galaxy tablet connected through phone worked for a hour tried the next day goes in stand but Garmin is on still.
Is this some glitch ,software issues waited 6 months for a unit, mate has had his for almost a year no issues tried all the forums solutions come on Garmin ,
Are there a certain number of shots you can hit before it enters standby mode, and does this occur on both Home Tee Hero and Driving Range Mode?
Does the issue occur both indoors and outdoors? How long was it working before it wasn't?
I just took out my new R10 for the first time today. I was outdoors and in driving range mode. I hit about 100 balls, the device was about 2.1m behind me, and I intermittently received the 'standby mode' message on my phone. The R10 was blinking green the whole time. I received the message 7 or 8 times during the session. Sometimes I'd go 20-25 balls without seeing it while other times it was every 5 or so shots.
Got my brand new unit if R10, it usually work for 30 min then hangs in Standby and blinks green, red and white. Then I loose connection. Try on off a few time! It should not be like this! Heat issue? Outdoor? Lease help asap, about to return the ubit!
The issue you are referring to is being actively investigated by our engineering team. A fix should be forthcoming. Please refer to main thread (3) 4.20 Wakeup Issues - Approach R10 - Golf - Garmin Forums.
I am locking this thread to prevent multiple running threads on this issue.
