Garmin Golf App: Disappearing Driving Range Sessions
Hi,
I have been playing with an Approach R10 for a few sessions at the range. Its great so far!
But I have a weird problem with the app.
The first 3 sessions are visible in the Golf Sim Sessions part of the app, however any of my most recent are not.
Actually they are visible, for a split second when i first open the sim sessions from the menu.
Then they disappear, and the first 3 sessions remain on show.
Any help appreciated
My Phone is an Android, Huawei mate 20 pro.
Thanks,
AL
  • Hello! Does uninstalling and reinstalling the Golf app make any difference?
    If you start a new session and end it, is that also disappearing or is that one being saved?
  • Garmin Rob, we have suggested that the app be able to work on landscape mode. No answer from you. Can you pass that to the developers. Please!!!!
  • Hi Rob,
    Thanks for the input. Yes i tried that but it was the same issues.
    However I have found out what was causing it. I just needed to restart my phone, then all the sessions appeared.
    Simple fix I know, but I'll post up for others that may be experiencing similar issues.
    Cheers,
    AL
  • I'm having the same issue. Eventually it showed up but it was hours later or the next day. I tried restarting my device and that didn't seem to immediately fix it.
    I've noticed that the latest range session appears for less than a second then disappears.
  • I am having the same issue. The device rest did not work for me.
  • Hello, have you tried restarting your phone?
  • Yes it did not work.
  • mine does the same thing eventually they show up but it a day or two later. reset does not work
  • First time for me today. Morning session pops up for a second then disappears. Reset doesn't help. All previous sessions before today stay there. I'll give it a chance and keep trying but tried a dozen times so far and same thing. Android, Galaxy S21 Ultra....
  • I had the same issue.
    Suddenly today,  R10 was disconnected and training range  session was also disappeared.
    I couldn't make the pairing again in normal process.
     I restarted iphone three times and reinstall the R10 golf app but couldn't fix the problem.
    What I did was I entered the iphone bluetooth mode and make the bluetooth  connection with R10 from there..
    The connection repeated On and OFF several times. I don't know why. Anyway finally  I managed to play the E6 for 20 minutes. Then I got message saying  "R10 was not FULLY connected. and try connection again"
    And then I could make the connection normally  based on the guided procedure.
    After that when I check the R10 Golf app, "driving range session" came back!!
    May be R10 app is not stable yet and same thing would happen again.
