Garmin, could you please look into this and perhasp issue a change as its really cumbersome without any obvious reason.
The G30 handles the very same situation perfectly and actually place the marker where you click.
Example - clicking display to mark a position to check distances.
- G80:
Puts the marker at 34 metres distance from the hole even if you click close to tee on a Par 5.
It also zooms in, so to even change this you have to press "Zoom out" and the click the desired position.
It takes three clicks to mark that position. - G30:
Instantly puts marker were you actually clicked.
