Complete
When is it not ok to call WatchUi.requestUpdate();?
Hi,
This one is a new one on me!
I saw an ERA log from onSettingsChanged that crashed out on my DataField onSettingsChanged handerl:
    function onSettingsChanged() {
        if(view) {
            view.onSettingsChanged();
            WatchUi.requestUpdate(); // CRASHES HERE
There is nothing contentious that I can see in onSettingsChanged (except a slightly annoying Attention.playTone that I had decided to remove on account of it being annoying in any case) - just some maths that is null checked, valid and safe.
So:
1. Is there any time that it is either illegal or unwise to call WatchUi.requestUpdate()
2. How does one test for that?
Thanks,
G
  • I also got this era a few months ago, as a result I've removed the line from the settings changed event handler. The watch face will update itself anyway at the slowest every minute, no real need to trigger an ui update.
  • [quote userid="3042" url="~/developer/connect-iq/f/discussion/246510/when-is-it-not-ok-to-call-watchui-requestupdate/1171478"]The only restriction I know of is you can't use it in a data field.[/quote] That might, just might be relevant here! [quote userid="156797" url="~/developer/connect-iq/f/discussion/246510/when-is-it-not-ok-to-call-watchui-requestupdate"]that crashed out on my DataField[/quote] Thanks, Slight smile
  • The only restriction I know of is you can't use it in a data field.  The screen will be updated once a second without it.
