Acknowledged
utf-8 and string resources
i have a problem with german umlauts (öäü) in string resources:
whenever i get the app from the ciq store (iq file) i only get "?" instead of umlauts while it works fine when i sideload the app or test in the simulator.
this happened before (see https://forums.garmin.com/developer/connect-iq/i/bug-reports/connect-mobile-and-utf-8-for-app-settings) and seemed to be fixed with SDK 3.2.3 but now using SDK 4.1.7 it re- appeared...
  • Is it really the same? In the old ticket you reported about problems in the app settings, and now you wrote that it works when you side-load, so I guess it's not about the settings now, but rather the strings that you display in the device. If so then it might be a problem with the font you use?
