Acknowledged
The sample projects Toasts and Selectable are broken in 4.2.0-beta2
% cd $sdk420/samples/Selectable
% "$sdk420/bin/monkeyc" "-o" "bin/Selectable.prg" "-f" monkey.jungle "-y" "$developer_key" "-w" "-l" "1" "-d" "approachs60"
WARNING: approachs60: The launcher icon (16x16) isn't compatible with the specified launcher icon size of the device 'approachs60' (40x33). Image will be scaled to the target size.
ERROR: approachs60: Could not resolve /images/back_default.png
ERROR: approachs60: Could not resolve /images/back_pressed.png
ERROR: approachs60: Could not resolve /images/menu_default.png
ERROR: approachs60: Could not resolve /images/menu_pressed.png
ERROR: approachs60: An undefined resource reference was detected during resource processing: @Drawables.DefaultBackButton.
ERROR: approachs60: An undefined resource reference was detected during resource processing: @Drawables.PressedBackButton.
ERROR: approachs60: An undefined resource reference was detected during resource processing: @Drawables.DefaultMenuButton.
ERROR: approachs60: An undefined resource reference was detected during resource processing: @Drawables.PressedMenuButton.
But if I compile it (the same project, taken from the 4.2.0beta2 samples) with 4.1.7 the compilation succeeds, and I can run the resulting program. So this is probably a bug in 4.2.0 (unless there's a subtle bug in the project that earlier compilers simply didn't notice).
For Toasts, I get
% cd $sdk420/samples/Toasts
% "$sdk420/bin/monkeyc" "-o" "bin/Toasts.prg" "-f" monkey.jungle "-y" "$developer_key" "-w" "-l" "1" "-d" "fenix7"
ERROR: Device 'fenix7' does not support API Level '4.2.0'.
And this time 4.1.7 agrees. So in this case it looks like the sample project needs fixing.
  • I'm going to report the issue your found attempting to build the Selectable app—I agree that looks like there may be a compiler bug. The Toasts error is primarily because of the API level supported by the devices (this will only work with the System 6 preview devices Jim mentioned). I'll get the manifest typo fixed, though.
  • This sample has been around for a long time, so I'm not sure what's up for you.
    Well, as I've made clear, what's up is that the new compiler (correctly in my opinion) rejects the non-relative paths on MacOS and (as Ive just verified) Linux. I've also confirmed that it still works on Windows.
    So, depending on what Garmin decides, its either a bug in the old compiler, and the new windows compiler, and samples/Selectable needs to be fixed; or its a bug in the new MacOS and Linux compilers, and the compilers need to be fixed.
  • my bitmap.xml is the same for selectable, and it builds and runs fine on win11 and if I look at the sample from 4.1.4, it's the same.  This sample has been around for a long time, so I'm not sure what's up for you.
  • Well, here's what's in bitmaps.xml
    <resources>
        <bitmap id="LauncherIcon" filename="images/icon.png" />
        <bitmap id="checkBoxDefault" filename="images/checkbox_default.png" dithering="none" />
        <bitmap id="checkBoxSelected" filename="images/checkbox_selected.png" dithering="none" />
        <bitmap id="checkBoxHighlighted" filename="images/checkbox_highlighted.png" dithering="none" />
        <bitmap id="checkBoxHighlightedSelected" filename="images/checkbox_highlighted_selected.png" dithering="none" />
        <bitmap id="DefaultBackButton" filename="/images/back_default.png" dithering="none" />
        <bitmap id="PressedBackButton" filename="/images/back_pressed.png" dithering="none" />
        <bitmap id="DefaultMenuButton" filename="/images/menu_default.png" dithering="none" />
        <bitmap id="PressedMenuButton" filename="/images/menu_pressed.png" dithering="none" />
    </resources>
    It's pretty clear that the absolute paths are incorrect there. In fact the surprise (to me) is that the older compilers accept this. But 4.2.0 does not (on MacOS at least).
    In any case, it just seems weird that Garmin would make a release without (at least) building all the sample projects on all supported platforms.
  • With the fenix7 vs fenix7system6preivew, it's probably just a timing thing.  There is alpha FW for the f7 with system6, but until there is production FW with that, devices for the SDK won't have that version.  Same with other devices like the fr255,955, and v2.
    The typo in the manifest could just be a fix didn't make it into the beta2 build (new sample. beta SDK, etc) but it's a pretty minor fix and the error message points you right to it.  That said, it should be fixed but could take some time until there is another update to the SDK (beta1 was mid Oct, beta2, mid Jan)
    I've not tried it, but I kind of doubt this can be used in watch faces.  The doc doesn't say.
