Acknowledged
Symbol Not Found Error: Could not find symbol 'KeyEvent'
Hi,
I have a class derived from WatchUi.View, that when is being shown gives the following error whenever I press the (physical) button on the clock (vívoactive 3):
(from CIQ_LOG.YML)
Error: Symbol Not Found Error
Details: "Could not find symbol 'KeyEvent'"
Time: 2022-07-20T14:17:47Z
Part-Number: XXX-XXXXX-00
Firmware-Version: '8.10'
Language-Code: por
ConnectIQ-Version: 4.1.4
Filename: -----
Appname: -----
Stack:
- pc: 0x30001d07
- pc: 0x30001fb0
In the simulator, I also can see the error:
Details: Could not find symbol 'KeyEvent'
Stack:
- handleEvent() at D:\grmn\prj\di\connectiq\toolchain\mbsimulator\submodules\technology\monkeybrains\virtual-machine\api\WatchUi.mb:1065 0x30002252
- handleEvent() at D:\grmn\prj\di\connectiq\toolchain\mbsimulator\submodules\technology\monkeybrains\virtual-machine\api\WatchUi.mb:1262 0x300024fd
The curious thing is that neither the class derived from the View nor the one from BehaviorDelegate has any reference to WatchUi.KeyEvent (in fact now they do, as I added it to try to see if I could overcome the problem by forcing the use of the "KeyEvent" symbol in those classes... with no success).
The stack trace seems to point to an internal API error.
Can anyone help?
Thank you
UPDATE
I found that the VM appears to be getting confused when the (user) namespace contains "WatchUi". Any class derived from WatchUi.View within a namespace or subnamespace with that token (eg XYZ.WatchUi, X.Y.Z.WatchUi or X.Y.Z.WatchUi.Sub) will produce the error when the physical button is clicked.
The following example works fine, but when we change the subnamespace from "WatchUi2" to "WatchUi" it will produce the error described above:
import Toybox.Lang;
using Toybox.Application;
using Toybox.WatchUi            as Ui;
using XYZ.WatchUi2              as XW;
class XYZApp extends Application.AppBase
    public function initialize()
        AppBase.initialize();
    public function getInitialView() as Lang.Array<Ui.Views or Ui.InputDelegates>?
        var result = [ new XW.EmptyWindowView(), new XW.EmptyWindowDelegate() ] as Lang.Array<Ui.View or Ui.InputDelegate>;
        return result;
import Toybox.Lang;
using Toybox.Graphics           as Gfx;
module XYZ
    module WatchUi2
        class EmptyWindowView extends Ui.View
                View.initialize();
            // Load your resources here
            function onLayout(dc as Gfx.Dc) as Void
            // Called when this View is brought to the foreground. Restore the state of this View and prepare it to be shown.
            // This includes loading resources into memory.
            function onShow() as Void
            // Called when this View is removed from the screen. Save the state of this View here. This includes freeing resources from memory.
            function onHide() as Void
            // Update the view
            function onUpdate(dc as Gfx.Dc) as Void
                View.onUpdate(dc);
import Toybox.Lang;
module XYZ
    module WatchUi2
        class EmptyWindowDelegate extends Ui.BehaviorDelegate
                BehaviorDelegate.initialize();
  • I dunno. From where I'm sitting this looks like totally valid code that should work as advertised. I would add your test case to your opening post and call it a bug.
  • Sorry, to simplify the XYZApp was hand edited (and wrong). The correct code is:
    (XYZApp.mc)
    import Toybox.Lang;
            return result;
  • I see you use the construct twice, replace where needed :)
  • You use YourModule.WatchUI as Ui and than say Lang.Array<Ui.Views or Ui.InputDelegates>? Ui.View and Ui.BehaviourDelegate are not extendin Toybox.WatchUi in your code. I think you are making the compiler a bit cray cray.
    What happens when you add using Toybox.WatchUI as NativeUi and replace Lang.Array<Ui.Views or Ui.InputDelegates>? with Lang.Array<NativeUi.Views or NativeUi.InputDelegates>? in your XYZApp.mc?
  • Here is the simplest code I have:
    (XYZApp.mc)
    import Toybox.Lang;
    using XYZ.WatchUi2          as Ui;
            var result = [ new Ui.EmptyWindowView(), new Ui.EmptyWindowDelegate() ] as Lang.Array<Ui.View or Ui.InputDelegate>;
            return result;
    (EmptyWindowView.mc)
    import Toybox.Lang;
    module XYZ
        module WatchUi2
                    View.initialize();
                // Update the view
                    View.onUpdate(dc);
    (EmptyWindowDelegate.mc)
    import Toybox.Lang;
    module XYZ
        module WatchUi2
    Nothing happens (nothing is supposed to happen in this case) when you click on the physical button (I tried with "vivoactive 3", but most probably others with physical buttons will do also).
    Now, change the module name from "WatchUi2" to "WatchUi" in EmptyWindowView and EmptyWindowDelegate, and also the "using" line in XYZApp.mc to "using XYZ.WatchUi as Ui" run it and click on the physical button...
