Acknowledged
storage setValue error
4.1.4/win/eclipse
on some devices I have an error  when trying save something in storage:
1. in app.onStop() - only in foreground I call app.savedata() (I need func because I need save data in few moments).
2. savedata() is called and inside I try to call STO.setValue() and errors:
A Error Name: System Error (vívoactive® 3 Music: 6.20) - 3 arrays[80] of float (each 415 bytes according to memory monitor), 1 array[20] of float (70bytes) and few integers
B Error Name: File Not Found Error (Forerunner® 945: 9.00) - saving dictionary (a bit complicated)
A - I don't think I exceed any limits
B - system detach storage before onStop()?
  • since this seems to not be a priority, perhaps it's time to go back to using properties to store data.  i get about 100 of these errors a month showing in era.
  • So this is still not fixed? I got a "System Error" on a Forerunner® 645 Music: 7.20 while doing
    Storage.setValue("PendingWebRequests", pendingWebRequests);
    where pendingWebRequests is a dictionary and the code is within getInitialView so, foreground.
  • I don't know how your code looks but if you have background reading storage is very often even background doesn't need it.
    yes, recently this bug shows usually on APAC devices
    Occurrences: 1
    First Occurrence: 2022-09-08
    Last Occurrence: 2022-09-08
    Devices:
        Forerunner® 945: 10.40
    App Versions: 4.3.2
    Languages: jpn
    Occurrences: 7
    First Occurrence: 2022-09-06
    Last Occurrence: 2022-09-07
    Devices:
        fēnix® 6 Pro / 6 Sapphire / 6 Pro Solar / 6 Pro Dual Power / quatix® 6: 23.00
    App Versions: 2.1.2
    Languages: eng, kor
  • I got nearly same issue onStart().
    Occurrences: 7
    Devices:
    fēnix® 6 Pro / 6 Sapphire / 6 Pro Solar / 6 Pro Dual Power / quatix® 6: 22.10
    App Versions: 1.7.0
    Languages: jpn
    Backtrace:
    AdditionalTimeStopwatchApp.onStart:16
        function onStart(state as Dictionary?) as Void {
            var targetTime = Storage.getValue("targetTime");
            if (targetTime == null) {
                Storage.setValue("targetTime", 45);  // <-- the backtrace line:16
  • every bug should be treated seriously - nobody knows when bigger problem came out
