Complete
WERETECH-7755
Fixed
Simulator won't boot on macOs Mojave
Hello there,
My problem is simple:
I've installed Eclipse, the connectiq SDK (3.0.12) and try to create and Simple Data Field app. It compiles and the simulator boot but then the device screen stays black with a blue triangle.
So I've opened a sample project (SimpleDataField) and build it to a Simulator and, again, the device screen stays black with a blue triangle
PS : here is what the simulator looks
Thanks in advance for your help
  • I've solve the problem I've done this in the Terminal: ln -s $TMPDIR/Garmin/ $TMPDIR/GARMIN ln -s $TMPDIR/Garmin/APPS/ $TMPDIR//Garmin/Apps
  • I've cleaned the install of ConnectIQ and now I've only /Users/pad//eclipse/connectiq-sdk-mac-3.0.12-2019-06-12-77ed6f47e/bin/ConnectIQ.app But it didn't solve anything
  • Thanks for your reply eclipse: /Users/pad/eclipse/java-2019-06/Eclipse-java.app connectIQ.app : find in terminal shows me 2 files /Users/pad//eclipse/connectiq-sdk-mac-3.0.12-2019-06-12-77ed6f47e/bin/ConnectIQ.app and /Users/pad//eclipse/connectiq-sdk-mac-3.0.12-2019-06-12-77ed6f47e/connectiq-sdk-mac-3.0.12-2019-06-12-77ed6f47e/bin/ConnectIQ.app
  • I've been running Eclipse with the ConnectIQ SDK (several different versions) on MacOS Mojave for some time, so it isn't an incompatibility problem. It is more likely to be an environmental issue of some sort. It looks like the simulator is starting, but there is some sort of problem pushing the application to the simulator to run. This is going to seem like a weird question, but what are the absolute paths to ConnctIQ.app (found inside the SDK) and Eclipse.app?
