Acknowledged
sdk 4.1.5 and Communications.makeWebRequest()
I've noticed recently BLE_QUEUE_FUL error - also on sim so it is not connected with GCM.
There is no information in readme but probably the limit of requests was decreased.
There is no word in doc about limits so for me there is no any limits and now something was changed and also without any info.
Maybe context in Communications.makeWebRequest() was fixed after few years?
  • Not sure where 3 outstanding is documented.  Maybe it was in older doc, but it's been that way for a long time. Just something I've known since the early days. You might get 4 if the 1st completes before the 4th is sent. so could be a timing issue.  The sim will be faster than using a real device/phone,
    The Android vs iOS difference I saw years ago.  Another dev and I were tracking down a bug that (as it turns out) happened after 65535 web requests from a garmin device.  He had iOS and was able to issue multiple requests at the same time.  I had Andriod, and was limited to one at a time.  Needless to say, he was able to get to 65535 much faster than I was.  (we were using the same test app and if I recall, we had a flag work with the two environments)
  • And of course i have to rewrite code and of course new code will consume more memory so limitation will increase.
    And the same with checking every value from API - is null?
    Recently I've noticed  that on f5 profile.sleeptime is null - according to the doc, can be null? yes so there is.
    But it's impossible to put empty value in gcm - so why this value can be null? And answer for future question - if you make new property in type system you have to add default value for all previous data instead of  adding can be null in doc.
  • 1. Where is this information in doc? Our maybe it's secret and only const in sdk?
    2. To the 4.1.4 it was possible to 4 (I don't need more).
    3. It is the horror to fight with platform limitation same restriction instead of functionality.
  • The limit has been 3 for a long time.  However with Andriod you only wanted 1 outstanding request at a  time for a long time so I code for that.  How many are you trying to do at the same time?
