Ticket Created
CIQQA-637
repeated makeImageRequest calls cause memory leak
I'm running a widget that makes repeated makeImageRequest calls and am noticing memory consumption go
up by 0.1 to 0.2kB for each call.  Looks like a memory leak. I'm using Connect IQ SDK 4.0.3 and users are reporting out of memory crashes.
I tried the widget app with every watch model in the simulator and the problem occurs on every model except Venu2 and Venu2s.
Incidentally the widget app under Venu2 and Venu2s takes extremely little memory to run compared to other models.  I'm not sure why.
  • I still don't see the problem.  I made a simple test project to demonstrate the problem.  Just create a default Widget project and paste this code in the view, and run.
    import Toybox.Graphics;
    import Toybox.WatchUi;
    import Toybox.Timer;
    class PhotoWidView extends WatchUi.View {
    var image;
        function initialize() {
            View.initialize();
        function onShow() as Void {
        triggerRequest();
        function onLayout(dc as Dc) as Void {
        var myTimer = new Timer.Timer();
        myTimer.start(method(:timerCallback), 1000, true);
    function timerCallback() {
        triggerRequest();
    WatchUi.requestUpdate();
        function responseCallback(responseCode, data) {
            responseCode = responseCode;
            image=null;
            if (responseCode == 200) {
                image = data;
    function triggerRequest() {
            var url = "">encrypted-tbn0.gstatic.com/images;
            var options =  {
                 :palette => [0x00000,
    0x555555,
    0xaaaaaa,
    0xaa0000,
            0xff5500,
            0x55aa00,
            0x5500ff,
            0xaa5500,
            0xffffff],
              :maxWidth => 240,        // set the max width
                :maxHeight => 240,        // set the max height
                :dithering => Communications.IMAGE_DITHERING_NONE   // set the dithering
            Communications.makeImageRequest(url, null, options, method(:responseCallback));
        function onUpdate(dc as Dc) as Void {
            View.onUpdate(dc);
            if (image!=null) {
            dc.drawBitmap(0,0,image);
        function onHide() as Void {
  • If objects and peak objects keep increasing, that's the first place I'd look.
  • OK I ran a test looking at the memory stats.  After a few imageRequests, Memory Usage went up by about 4k, Object usage, and peak objects goes up by 1 for each imageRequest.  But examining the detailed categories of memory, I haven't found any one of them change in size.
  • The venu2/venu2s has much more memory for widgets than most other devices (763k).  Also, the v2/v2s is the only device that has the graphics pool, so things like bitmaps and custom fonts are not in the apps memory space, but in the graphics pool.  Same with makeImageRequest data.
    On a real device, widgets time out and close in 1-2 minutes, where in the sim, they will run forever.  Have you tried to use "view memory" in the sim to see what's going on?
