Complete
over 5 years ago
WERETECH-8515, VVA4-4657
This is fixed as of the 4.50 firmware release for vivoactive 4.
latest fw update on VA4 killed behaviorDelegate
My app NASA PoD was working just fine on a number of devices and in the simulator.  I just updated my VA4 firmware (4.00, GPS 2.7) and the widget no longer scrolls within the text display using behaviorDelegate.  I tried a few things and it still does not work on the actual device.
class TextViewDelegate extends Ui.BehaviorDelegate {
    var isTouchScreen;
    function initialize() {
        BehaviorDelegate.initialize();
        isTouchScreen=Sys.getDeviceSettings().isTouchScreen;
        isTouchScreen=false; //override in attempt to fix VA4 bug
    function onBack() {
        //Sys.println("onBack");
        Ui.popView(Ui.SLIDE_IMMEDIATE);
        return true;
    function onNextMode() {
        //Sys.println("nextMode");
        return onNextPage();
    function onNextPage() { // scroll down
        //Sys.println("next");
        if(!isTouchScreen) {
            scroll(:UP);
            return true;
        return false;
    function onPreviousMode() {
        return onPreviousPage();
    function onPreviousPage() { //scroll up
        //Sys.println("prev");
            scroll(:DOWN);
            return true;
        return false;
    function onSwipe(evt) {
        var dir=evt.getDirection();
        //Sys.println("swipe: "+dir);
        if(dir == Ui.SWIPE_UP) {
            scroll(:UP);
            return true;
        if(dir == Ui.SWIPE_DOWN) {
            scroll(:DOWN);
            return true;
        return false;
    function onHold(evt) {
        var coor = evt.getCoordinates();
        //Sys.println("onHold"+coor[0]+", "+coor[1]);
        return false;
  • Thank you jim_m_58. I didn't know it affects other devices other than VA4/VA4s!
  • You may want to re-check your check, as you may want to include the venu, va4s, and the va4/va4s vaients (Rey,Darth Vader, etc) devices.
    It might be easier to use Jungles for this with excludeAnnotation
  • I've made the following workaround for my 2 widgets:
    - use onSelect() to do what is supposed to be in onNextPage()
    - use onMenu() to do what is supposed to be in onSelect()
    - sacrifice whatever is in onMenu()
    - sacrifice onPreviousPage() function
    Both my widgets do not have onMenu() so user can still use tap to go to the next page, long press the lower right button (menu) to select items. When the end of page is reached it wraps around to the first page.
    Use the following code to determine if it's running on VA4 to enable the workaround.
    var dev = Sys.getDeviceSettings();
    var isVA4 = false;
    if (dev.partNumber.equals("006-B3224-00") || dev.partNumber.equals("006-B3225-00")) {
        isVA4 = true;
  • Yes I've done the same testing as well. It's not possible to get it working at all.
  • It's very frustrating that built-in widgets work well and our widgets cannot work at all...
