Acknowledged
keyEvent.getKey() == 4 short vrs long pressed
Hi! I have the following problem, you might know the reason/solution.
I have the following code line:  if (keyEvent.getKey() == 4) {onSelect_lauch();}
I found that, in the simulator, for several devices, when I press the "Start-Stop buttom" (Key 4), if I press it long (not just one click but a "long" click), it launches properly the function but if I press it short, I gives me the typical error "Symbol Not found Error". It is an App (not a widget).
Error: Symbol Not Found Error
Details: Failed invoking <symbol>
Stack:
Do you know why and how to solve it?
Thanks!
  • You are right, good comment, I have also added it to not block older devices. Regarding the line thar is crashing, how could I know it? The Stack: line is empy...
    Oh interesting. I didn’t realize that was literally the whole error message.
    If I have a chance I’ll see if I can reproduce this problem in the sim. Jim did correctly point out that you’re supposed to return true in your onKey() event handler if you handle the key, and false otherwise.
    e.g.
    function onKey(keyEvent) {
      var key = keyEvent.getKey();
      if (key == 13) {
        slide_left();
        return true;
      if (key == WatchUi.KEY_ENTER) {
        onSelect_Battle();
        return true;
      return false;
  • Thanks your your reply. However, this does not seem to be the problem. I tried with your code and still not working...the problem is the duration the buttom button 4 is pressed. If pressed just once, quick, does not work, if pressed once long (push, wait, release) it works...
    Fair enough, but my point still stands. WatchUi.SLIDE_BLINK will not work on older devices, such as Vivoactive 3. This may be fine if you don't intend on supporting old devices.
    It would help to know exactly which line is crashing.
  • You may want to only do "return true" for keys you handled and "return false" for the others.
  • Seems that the following code works well:
    public function onKeyReleased(evt as KeyEvent) as Boolean {
            var key = (evt.getKey());
                onSelect_Battle();
            return true;
